Full Version: .pls radio stream from WXPN
WXPN in the northeast US.
The station streams just fine in Firefox.
This is the link supplied on the web page for the .pls format:
http://wxpnhi.streamguys.com/listen.pls
I donwload the .pls file and it contains the following:
cat listen.pls
[playlist]
NumberOfEntries=1
File1=http://wxpnhi.streamguys.com:80/xpnhidale
I have tried navigating to the file in XBMC.
I have tried entering the first url.
I have tried entering the url in the .pls file directly.
Nothing happens.
After reading through here a bit I get the sense that I should be able to point XBMC at the .pls file and things should go well.
What blindingly obvious thing am I missing?
No one uses .pls files?
Dalej Wrote:WXPN in the northeast US.
cat listen.pls
[playlist]
NumberOfEntries=1
Nothing happens.
try changing the extension to .m3u
xbmchead Wrote:try changing the extension to .m3u
|-<Smile
Tried that - it looks sort of pukes the html of the link into the file listing interface.
Wish I could grab a screen shot to show you.
Dalej Wrote:Tried that - it looks sort of pukes the html of the link into the file listing interface.
edit your m3u file to just have the url in it only
try again it will work
xbmchead Wrote:edit your m3u file to just have the url in it only
|-<Smile
Nope. Locked up xbmc so solid I have to yank the power on the mac.
Correction - I was able to ssh in and do a shut down.
Contents of the xbmc.log right before I did the shutdown:
http://pastebin.com/embed_js.php?i=LC7s27wM
I can click on the exact same file on my Linux desktop and it fires right up.
dale@dale:~/Desktop$ cat listen.m3u
