Full Version: Auto kai sign-in
is there any way at all to set xmbc to log in to a kai engine on your pc automaticallly on startup? perhaps with a autoexec.py script or such like?
or, if that isn't possible, what about configuring a shortcut on the xbox remote to go to the kai window using windowactivate() .. i have no idea how to do this, so any tips would be much appreciated
tia
f
xbmc will auto login provided, the engine is running before xbmc is started and provided you have supplied a username a password in the kai network settings. you may need to tweak the kai engine settings on the pc so that it doesn't shutdown.
