Full Version: Export XBMC video and music databases to HTML index files with images, etc.?
Is there a html template or similar out there that is able to read the xbmc database?
I would like a fine list I could host on my webpage, preferably with thumbs and movie details.
Movie Collector from collectorz.com can export its database to html (example) and I like the layout.
This program is not free Sad and I know xbmc scrapes better info then movie collector.
So is there anything out there that is able to make a similar database export to html from the xbmc library?
You can export the library to xml and then write a script to parse the xml and convert it into this.
Writing scripts is not my strong side Smile
Thats why I ask if there is anything out there that will do the job for me?
An existing script or program.
I was looking for the exact same thing today. I made a very, very basic html listing using thisxls file and xsltproc. It just lists the title and year of each movie with a hyperlink to moviedb.org.
More ino here
If you want to avoid parsing xml or querying sql you also have the option to call jsonrpc (this is what the webinterface is using to produce the information)
Thanks! I'll check that out.
Hello,
You can try XBNE, you just give it a file with html tags data. see the sample file in xbne directory ...
I want to exoprt my Movies and TV Series to a HTML page that can be edited (Custom Templates)
I Tried tons of softwares, but some of them is scrap the movies from imdb and I Don't want to rescrap the db..
I search something that will use the videodb34.xml that xbmc exports..
Did you try exported to a single file from within XBMC?
of curse, the result:
[IMG=http://img269.imageshack.us/img269/6069/31036887.th.jpg][/img]
Uploaded with ImageShack.us
now I search tool that can take this xml file and make it to nice HTML file...
that I can upload to my site and show to my friends what a nice collection I have
