There is a dialog that comes up when pictures are loading, I cant get it to come back up but it said "getting picture info" or something of that nature.
Also, what xml files are these linked too?
DialogOK
DialogYesNo.
damn, we should obfuscate!
igotdvds Wrote:There is a dialog that comes up when pictures are loading, I cant get it to come back up but it said "getting picture info" or something of that nature.
most likely DialogBusy.xml
ronie Wrote:most likely DialogBusy.xml
No, busy is the one with the ugly green writing that says "working". lol
spiff Wrote:DialogOK
DialogYesNo.
igotdvds Wrote:No, busy is the one with the ugly green writing that says "working". lol
yeah, you're right...
hmm...DialogKaiToast.xml ?
DialogProgress.xml (it has a progress bar on it)
If using a build above 29100 you can enable skin debugging with:
<debugging>true</debugging>
in your skin.xml file. helps in tracking down those dialogs...
With xbmc
Debug Log it is also possible.
Edit: but ..that even better onscreen wtf didn't know thanks mcborzu.
Thanks to everyone for their input.
