I'm running archlinux, and none of my custom skins are being loaded with the latest builds (tried 29815,29816,29817).
They do not show up in the list at all.
My skins are located under ~/.xbmc/skin/
It's the first time I run a svn build on this machine though, what am I doing wrong?
It seems like I had to place them under /.xbmc/addons/ , and create an addon.xml file.
Is this new? I can't find this documented anywhere.
rzReaver Wrote:It seems like I had to place them under /.xbmc/addons/ , and create an addon.xml file.
yes this is very new, to new for any documentation :-) feel free to write one :-)
It's part of the addon merge which recently included skins.
There's little to no document ion on this for various reasons.
I see, any chance you have a pre-merge revision number?
(I searched, but couldn't find anything related)
rzReaver Wrote:I see, any chance you have a pre-merge revision number?
as i see anything
before 29211
