Full Version: Downgrade XBMC
Hi Guys,
I recently tried the latest nightly xbmc build r29791 then decided that the ability to use my aeon skins is somewhat more important to me than having the vdadecoder.
i tried installing older xbmc but i lost my library .. and the ability to scan too.
any advice?
The library databases are not backwards compatible. If you updated to one of the development builds your library will now now work with an older build.
You will either need to restore your database from a backup, or delete the database for it to work again.
How do I delete the database?
Btw, even after adding a new source and set its content (scrapper to use) I couldnt perform a scan .. (there is simply no option)
Thanks for the help
edit: never mind. It seems I did something that re enable the scanning process..
I moved the database folder out of the \userdata\
