Full Version: Probleme after update r331
Hello,
First sorry for my poor england im french.
Im use xbmc R28256 (Trunk), and svn transparency, but after de last update (r331 and next) , the skin are not reconnu ( normal skin.xml are remplaced by addon.xml).
Im install de the last version of xbmc ( r29791) and copied de skin in the "addons" and renamed it (skin.transparency-xbmc) , but doens't not work to ??
Thank for you help.
Ps: possible to reponse in french Huh
you'll need xbmc r29814 or up.
also, use skin.transparency as a foldername.
hello,
I took the version (R29791) by http://sshcs.com/xbmc/, or find a version 29814 or up ?
just wait a day (or two) and it will be there.
After Updating skin to r340 using xbmc r29791 , xbmc won't load were as before updating the skin everything was working fine. please help ronie
as i already mentioned a few posts up:
Quote:you'll need xbmc r29814 or up.
Hello,
the skin re-operate it properly in re putting the file "skin.xml" ??
yes. ;-)
Hello,
Is possible to post the last version of this file , because tortoise are delete the file in the update.
Thank you
you can still download it from svn:
http://transparency-xbmc.googlecode.com/...k/skin.xml
hello,
thank you very much.
