2010-05-10, 01:22
I need to do this to fix the audio sync bug in Camelot. I have a minimal install of Jaunty with camelot installed, and startup script to boot directly into XBMC.
I want to upgrade to the last SVN version of XBMC that the dev team stated before the freeze. (what build # was that?). I will be backing up my current install with CloneZilla before starting this process.
I figure that this would also be a good time to upgrade Jaunty to Karmic, and then upgrade XBMC to the last suggested SVN release prior to the freeze.
Can somebody walk me through the best steps for completing this and which order to go with? I do not have a problem compiling XBMC from source, I just want to get that specific SVN version.
Will I uninstall my existing version of XBMC? Or can I upgrade it via the SVN installation? Thanks for any help with this.
-hogfan
-hogfan
