Hi i decided that I want to buy the Zotac ZBOX, when it comes out... as i am a windows user, I can make it work with win7 and xbmc, but what i really want is to instal the xbmc live cd on it with wifi and remote but I hav no clue on Linux, is there someone interested in Belgium who would help me set-up the thing?
thx,
Peter
The next release of XBMC which isn't too far away I believe will have video decoding hardware acceleration under Windows 7 so you should be all set once its out.
Getting XBMC Live up and running isn't too difficult, I would recommend using erhnam's modified Live release called
xbmcfreak it includes lots of tweaks for Ion systems and takes some of the work out of setting up XBMC Live.
A straight forward way to install that is to;
* Get a USB CD/DVD drive, burn image to disc using
Imgburn.
* Get a spare USB flash drive a couple of gigabytes in size.
* Boot from the CD and install xbmcfreak to the USB flash drive.
Now when you want to start XBMC Live just boot off the USB flash drive on startup and your windows install is untouched.
