I have tried to install the remote following the wiki tutorial, but i am failing. My version is the german/asian edition, which has inbuildt IR.
Conclusion:
Can anybody give me a simple guide from scratch to install the remote on Asus Eeebox 1501 (german/asian edition)?
I had the same problem, but was able to correct it.
Basically, I followed the steps on the wiki here:
http://wiki.xbmc.org/index.php?title=HOW...an_Edition
but ignoring the first 2 lines:
xbmc:$ sudo apt-get install lirc lirc-modules-source module-assistant
xbmc:$ sudo dpkg-reconfigure lirc-modules-source
Okay, well done. Im gonna try it soon. Can you tell me how to add this:
activate the script at startup. edit rc.local
xbmc:$ sudo vi /etc/rc.local
add the following:
/bin/sh /home/xbmc/start_ite8713.sh
when i C/P this into terminal, i get nothing and i cant ctrl+x to save and quit. Im quite bad at terminal i know
try "sudo nano /etc/rc.local" instead of vi, might be easier than vi.
Yeah, use "pico" instead whenever you see "vi" in a command. Pico is way more intuitive than vi.
Thanks alot guys.. Now i can move back to linux/xmbc
Sorry for going a bit off-topic: Does anyone know if it is possible to configure the Eeebox 1501 (the version with built-in IR receiver) so that one can use the remote in both WMC and XBMC under Windows? The path I have followed so far has led to meddling with both registry-files and xbmc's keyboard.xml - and still I'm not quite happy.
The solution (the easiest) is eventghost. I use eventghost, and can control both wmc and xbmc. The green button starts wmc, and the teletext button starts xbmc.
There is a guide for it here:
http://forum.xbmc.org/showthread.php?tid...highlight=[windows]
Its quite easy. Though i havent programmed most of the buttons. The guide was made, when xbmc didnt understand most buttons on mce remote. So i would recommend you only install the teletext button and a few others.
(du kan få det på dansk også, hvis det er
Should work fine.. Im no master in wmc
Could some more people test my solution posted
here without the start_it8713.sh script?
Could you explain how to test?
Under Karmic I had my remote working ok using the wiki tutorial, but had some problems with Lucid. Searching for a fix I came to the solution posted here:
http://forum.xbmc.org/showpost.php?p=539781&postcount=9
The only thing I did was remove the start_ite8713.sh script from /etc/rc.local and made the changes to /etc/init.d/lirc described above. Now everything works fine for me in XBMC and Lucid.
I have made a small guide to install XBMC live and remote on Asus Eeebox 1501 its on danish and you can find it
here
stefanwa,
Your fix worked perfectly for me. I couldn't actually get the other method to work properly, but this worked well. I'd say update the wiki with your solution.
