Full Version: Mapping a key on the remote to delete a file: possibile?
I've read that someone just ask this with no luck.
I've I guess the same request.
I'd like to map a key on my remote that immediately goes to the DELETE FILE function. So I just have to confrim (YES) to proceed.
Is there a way?
Thanks for your help.
There is a delete action. Does that not work?
http://wiki.xbmc.org/?title=Keymap.xml
kraqh3d Wrote:There is a delete action. Does that not work?
Do you mean this one?
Delete Used in My Files to delete a file.
I'm looking for a way to delete files that I share on my PC directly.
I mean inside the folders, not passing by My Files section.
Do you understand?
You probably want to tick the box that says "Allow file renaming and deletion" in settings...
http://wiki.xbmc.org/index.php?title=App...e_Settings
