Full Version: Skinning Question
Hello All,
I have XBMC Live running perfectly in the Confluence skin, but want to run the Aeon skin to improve the eye appeal of it. The problem that I am running into is the little badges at the bottom of the screen that display things like h.264, dolby digital, blu-ray etc... they display fine in Confluence but when I switch to Aeon some of them are just gray circles with a question mark in the center of them. I would like them to display just like Confluence does, does anyone know what might be causing this or how to correct it? I added in the blu-ray tags manually in the file names but didn't touch anything else.
Any information is appreciated.
Are you using one of the Aeon mods?
Hitcher Wrote:Are you using one of the Aeon mods?
I do not believe so. I just downloaded the skin and then put it into the skin directory on my XBMC machine. The skin works fine otherwise its just the little meta data tags on the bottom are acting a little funny. They work fine under Confluence.
Anyone have any idea?
Yes, the 'old' Aeon used the workaround method for meta data so you'll need to use one of the mods to get it working.
