Full Version: [Pre-merge] Cant see default.py in filebrowser
AS title says in my skin I can't see OSDsubtitles's default.py but in Confluence I can. My pre-merge version is 28032:
Here are the two to compare, I don't notice anything?
Night:
PHP Code:
<itemlayout width="750" height="40">
control type="label">
posx>0</posx>
posy>5</posy>
width>750</width>
height>25</height>
aligny>center</aligny>
font>Font_Bartowski_Movies_Duration</font>
textcolor>white</textcolor>
info>ListItem.Label</info>
control>
itemlayout>
focusedlayout width="750" height="100">
posx>0</posx>
posy>30</posy>
width>750</width>
height>25</height>
font>Font_Bartowski_Filebrowser</font>
textcolor>mainblue</textcolor>
label>[UPPERCASE][b]$INFO[ListItem.Label][/b][/UPPERCASE]</label>
control
Confluence:
PHP Code:
<itemlayout height="40" width="640">
control type="image">
posx>0</posx>
posy>0</posy>
width>640</width>
height>41</height>
texture border="5">MenuItemNF.png</texture>
control>
posx>10</posx>
posy>2</posy>
width>38</width>
height>38</height>
texture>$INFO[ListItem.Icon]</texture>
control>
posx>55</posx>
posy>0</posy>
width>580</width>
height>40</height>
font>font13</font>
align>left</align>
selectedcolor>green</selectedcolor>
control>
itemlayout>
focusedlayout height="40" width="640">
posx>0</posx>
posy>0</posy>
width>640</width>
height>41</height>
visible>!Control.HasFocus(451)</visible>
control>
posx>0</posx>
posy>0</posy>
width>640</width>
height>41</height>
visible>Control.HasFocus(451)</visible>
texture border="5">MenuItemFO.png</texture>
control>
posx>10</posx>
posy>2</posy>
width>38</width>
height>38</height>
control>
posx>55</posx>
posy>0</posy>
width>580</width>
height>40</height>
font>font13</font>
align>left</align>
control>
focusedlayout
Thx for any replies...
Noticed that too in 28276.
what's the code you use to launch the filebrowser?
edit:
nevermind, found it. you're using 'post-addon' code:
<onclick>Skin.SetFile(SubsScript_Path,Script)</onclick>
change it to:
<onclick>Skin.SetFile(SubsScript_Path,.py)</onclick>
and you should be fine. ;-)
Actually I used T!'s post merge code:
Looking at a pre-merge confluence, it uses:
<onclick>Skin.SetFile(SubtitleScript_Path,.py)</onclick>
Yep, just tried the switch that was it, thx Ronie...Newer post-merge way is way nicer, it automatically takes you to the correct section and only takes 2 clicks.
