Full Version: [BUGS] and missing items
Aw well, all done...lol
I deleted everything and started over. It's all good now, not sure what my issue was the first time.
Sets work now too, YEA!
Now we just need those smart playlists
I'll try and knock out Playlists soon, I could never fiqure out how to work them. Waffa and >>X<< explained pretty well in another thread so I should be able to manage...
**EDIT**
Well that was simple took about 15 seconds to create one for HD movies, lol
When you view the cast in the movie screen the second column overlaps the poster and media flags
mcborzu Wrote:I'll try and knock out Playlists soon, I could never fiqure out how to work them. Waffa and >>X<< explained pretty well in another thread so I should be able to manage...
**EDIT**
Is GIT updated?
**EDIT**
I really should look at the release thread before I post stupid questions...lol
I will be adding the function to put playlists on Home, there really cool...the wiki kind of scared me. It started talking about text files and it looked confusing. Anyways once those guys explained it at a 5th grade level I found there really easy and powerful.
Sweet! Looking forward to it
Take a look into Wall Panel, I updated to the new version and I seem to have two Global Times. One in the top right corner and another in the bottom right corner covering the flags.
mcborzu Wrote:I will be adding the function to put playlists on Home, there really cool...the wiki kind of scared me. It started talking about text files and it looked confusing. Anyways once those guys explained it at a 5th grade level I found there really easy and powerful.
Hehe Big Grin sounds difficult but it is so easy to create them.
Hello
2 littles things in the WallPanel view ..
Thanks you
Hello, I make the last git update and now there is two "now listening info" in this view.
Thank youWink
XavHorneT Wrote:Hello, I make the last git update and now there is two "now listening info" in this view.
Thank youWink
Seemed fine on my end:
I'm also getting the two "now listening info".
in panel and wall panel views.
Don't know how we're getting different results but I slowly went thru all views and noticed some errors so global now playing should be solid after tonights update...
I love this theme but having issues that are annoying me.
I am using AppleTV.
9.11 of XBMC.
Apple Remote.
Downloaded Night 2 mins ago from GIT.
Ran logo script. Can see logo's in each folder fine.
I click on TV Shows link. Error pops up. "Error Operation not Permitted"
I hit ok.
I am in the landscape mode. Logo's dont show. When moving left / right the above error message pops up each time. When changing viewtype the above error pops up each time.
I have tried doing doing a clean install of XBMC and the skin. Tried cleaning the library etc but keep getting these errors.
Any way to solve this? I.e getting the logo's to show and stopping the errors?
I've got the same issue regarding the two 'Now playing', only what I've got duplicates of is the Global Clock (viewtype - Wall)
In the bottom and top right corners.
ISYM Wrote:I love this theme but having issues that are annoying me.
I am using AppleTV.
9.11 of XBMC.
Apple Remote.
I hit ok.
not skin related, it's a problem with live distrib and smb share, try to mount your share, it would be good.
