butchabay Wrote:I can't enter the pictures section, can someone confirm that?
I had this when i had a Virtual CD mounted dismounted the CD and worked fine again hope that helps.
The only thing this skin needs now is the ability to download lyrics.
isamu.dragon Wrote:The only thing this skin needs now is the ability to download lyrics.
Really just waiting for someone to ask
I actually use XBMC in the most basic way - Movies and TV. I barely use anything else so I don't know how popular some stuff is...but sure, give it a little.
pletopia Wrote:genre posters .. not backdrops
No sir we have the posters now its the backdrops we are missing or the option to have them :-)
I found some minor issues or have some remarks:
1. What happen to the scrollbar? After updating to the latest git version, the behavior changed. In the video section on files view if i move right now, there is no scrollbar anymore. Instead moving left / right seems to move pages up / down. But also not preciously, because there are at least 4 elements skipped (last one of a page is not first of next, you need to move 4 items up to find it).
In Music & Pictures, the scrollbar and the ability to move pages disappeared completely
2. If I change in Movies-Genre the viewtype to poster, there are then 5 options but still only 4 headings.
3. In Movies if there are sets, it says Minutes below the title. I guess this is a left over from the normal movie information, where the minutes make actually sense. Not really a big issue, but maybe there is a way to hide it for movie sets.
4. Is there a reason why under Settings-Addons, if I select an addon for more information or open the changelog, I need to use ESC to get out? Normally everything works with backspace, just here I need ESC.
In general I still think it is a great skin, so keep up your good work!
Ram2000 Wrote:No sir we have the posters now its the backdrops we are missing or the option to have them :-)
i'm confused .. the link you posted takes to a post that has 2 sets of posters .. not backdrops
pletopia Wrote:i'm confused .. the link you posted takes to a post that has 2 sets of posters .. not backdrops
Its easy to get mislead the skin doesnt support Genre Backdrops at the moment the posters are there for all to use.
Hi all,
This is my first post on the forum and I want to say hello to everyone. Also I want to say thanks to @
mcborzu for a great skin. As my addition to your work I attached pack of modified fonts for Night skin. Now all polish characters in the skin are displayed correctly. MCborzu if you want to add this to your skin I bet that many polish users of xbmc and your skin will be happy. Thanks.
http://www.mediafire.com/?fky9tg79gbpcpg8
Ram2000 Wrote:Its easy to get mislead the skin doesnt support Genre Backdrops at the moment the posters are there for all to use.
okay .. so you want him to support something that doesn't exist ?
Ram2000
Do you have a pack of 'genre fanart'...I searched the forum and didn't find any, thx.
Small request (hopefully): I noticed there is a "square" 3d poster view for music albums. Could this be allowed for addons/programs/scripts? Specifically, this would be nice for things like launcher where the covers for emu games don't fit nicely into the normal DVD poster size.
mcborzu Wrote:@Ram2000
I've got a pack of 'genre fanart' that I used with Aeon, maybe did some changes to it don't remember, would that be good? It's
this if you want to take a look. Will music genre fanart be enabled too?
Also could the addons in the home menu, show the same menu like when you click on addons in settings, right now it only shows 'get more', think it would be better if it shows 'enabled' and 'get more'.
