Full Version: [BUGS] and missing items
windows7? look into the user\username\appdata\roaming\xbmc
On xbmc live, why should I go there? What am I looking for?
ohh live. don't recall how linux works. might try delete textures.db
Ah thats it! Thanks Zwat.
Edit: Worked. Its an annoying bug and happened to me a few times before I just keep on forgetting what to delete.
I love this skin. I've tried them all, and this is by far the best one.
There is just one thing I wanted to ask.
Do you plan on adding more views to the music section? The only thing I am not 100% loving, is the music views.
I would love to have something more like in the attached image.
it´s me or my pc?
I´m usin dharma beta 2, night skin; and when i see a film, just for the end, i press X to stop and go to the menu, but it´s nothing hapend, it´s freezed!!
Recently added tv shows on home. The fanart wont show when adding new shows. I tried deleting the texture.db file, but it doesnt help. All that shows is a ? even though inside of the directory itself the fanart shows fine. Any ideas? Its also weird cause shows i added before have the fanart show, its just the new ones that wont.Huh
1slimm31 Wrote:Recently added tv shows on home. The fanart wont show when adding new shows. I tried deleting the texture.db file, but it doesnt help. All that shows is a ? even though inside of the directory itself the fanart shows fine. Any ideas? Its also weird cause shows i added before have the fanart show, its just the new ones that wont.Huh
Beta2/W7 here and obviously the most current version of Night and it's working just fine. I haven't touched that area of code in forever except it now fallbacks to the default TV image not that ? image. Actually one show it wouldn't show the fanart but all others were fine?
Make sure you have the most recent.
Newest view:
1. long plots get cut off in the right side.
2. menu cant get right, only left.
psike Wrote:Newest view:
just pushed will make official repo
did you meant it's already update?
cuz i've just did a git pull and the menu is working fine but the plot is still cut.
here a screenshot:
@psike What view is that? Is that a recently added script or something?
msderganc Wrote:@psike What view is that? Is that a recently added script or something?
it was added a few weeks ago.
http://forum.xbmc.org/showpost.php?p=607...count=1314
psike Wrote:did you meant it's already update?
here a screenshot:
Damn, early morning, I fixed itemlayout and not <focusedlayout> too
Did a fresh install from git and just edited the flagging XML. Whenever I click on the subtitles script button it takes me to the settings menu even though the subtitle add on is correctly linked. Anyone else get this?
Edit: just tested it in confluence the subtitle feature works so it's definitely related to the skin itself, any idea on what could have caused this?
