Full Version: [BUGS] and missing items
where did the *watched* info on viewtype_landscape_fanart.xml go? i miss it dearly
zwat Wrote:where did the *watched* info on viewtype_landscape_fanart.xml go? i miss it dearly
I went the easy way out when I included the recently added. Just so it's one less thing to worry about. If recently added is off it shows, I can now use some <visibles> so both work...
Fantastic skin, I love the halo around the lettering. Slight
problem/question, When wanting to watch a movie or TV program I
usually choose "Files" not "Newest" as I want to see my full library
not just the latest added files. My issue is both, files under movies
and files under TV, lead to the same place (as shown in the pix).
Pleas helpHuh
Is there a way to integrate the record button for Shoutcast streams ?
Can't find it in your awesome skin. :confused2:
Thanks in advance !
P.s. running on Dharma2
Raptylos Wrote:Is there a way to integrate the record button for Shoutcast streams ?
Thanks in advance !
Can you link to the addon, so I can download. Also what skin(s) have the button so I can look at there code, thx...
mcborzu Wrote:Can you link to the addon, so I can download. Also what skin(s) have the button so I can look at there code, thx...
The addon is the Shoutcast-addon availiable through the addon-manager under music addons. The record-button is implemented in Confluence right in the music-osd.
DialogVideoInfo.xml does not include the mediaflag color toggle.
A week ago I updated the skin using the XBMC add-on update and the background for the weather on the main menu disapeared.
I already posted a question regarding this regression (http://forum.xbmc.org/showpost.php?p=616...tcount=642 but still no response.
Any ideas?
dora Wrote:A week ago I updated the skin using the XBMC add-on update and the background for the weather on the main menu disapeared.
Any ideas?
The conditional weather folder setting has been moved to Skin settings - Home window, right below "Use Condition based weather fanart".
There you have to set the path to your weather fanart.
Raptylos Wrote:The conditional weather folder setting has been moved to Skin settings - Home window, right below "Use Condition based weather fanart".
Whether I'm doing something wrong or it is still broken but the conditional weather is still not working.
I could find two settings that might be related to the conditional weather.
1: Skin -> Home Window -> Use Conditional based weather fanart and Set Conditional Weather folder.
2: Skin -> Background -> Weather -> Multi Image.
I think that I've tried any conbination of the two but still could not make the conditional weather fanart to work.
The conditional weather folder has 49 folders in it, numbered from 0 to 47 and one more named 'na'. (I think that I took it from the Transparency skin).
Another point that is worth mentioning again is that the conditional weather was used to work before last week update.
Ok, so now I'm trying to navigate to movies/tv through the Videos option. I also changed the viewing angle to horizontal. According to your release trailer there should be a way to bring up a grey box at the bottom of the screen with blue options. I can't for the life of me find out how to bring that option box up though. I've tried dragging my mouse all over the place. Still nothing. Pleas help
KidVulcan Wrote:Ok, so now I'm trying to navigate to movies/tv through the Videos option. I also changed the viewing angle to horizontal. According to your release trailer there should be a way to bring up a grey box at the bottom of the screen with blue options. I can't for the life of me find out how to bring that option box up though. I've tried dragging my mouse all over the place. Still nothing. Pleas help
Skin not designed with mouse support. Easiest way to bring those options is the press the opposite way you are navigating...
mcborzu Wrote:Skin not designed with mouse support. Easiest way to bring those options is the press the opposite way you are navigating...
dora Wrote:Whether I'm doing something wrong or it is still broken but the conditional weather is still not working.
Working on my end. Never hurts to try another skin to double check...
mcborzu Wrote:Working on my end. Never hurts to try another skin to double check...
Good idea.
It is just that I love this skin so much so it didn't cross my mind to try another skin Smile.
I'll test it with another skin once I'll get home.
Ah, so keyboard then. What key is best for bringing up those options-arrow keys, space bar ect?
