Unable to reproduce it now due to updating the plugin and my log has been wiped.
It simply doesn't start anymore throwing an error instead. But yea... it was trying to start everytime i navigated to the home menu. lol
no, it should only be launched by skin at start , end users have nothing to do + there's no need to launch it each time you are on home.
ppic Wrote:no, it should only be launched by skin at start , end users have nothing to do + there's no need to launch it each time you are on home.
I threw on Home also so if you switch skins it'll be launched and not sure that alarm parameter will be triggered if only in startup, plus I wasn't having any errors. If I'm going to guess people might be using the older version of the next aired script.
I'll switch next upload with it only triggered on startup...
19:13:33 T:4456 M:1357066240 NOTICE: WebServer: Started the webserver
19:13:33 T:4456 M:1356992512 NOTICE: ES: Starting event server
19:13:33 T:6536 M:1356742656 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
19:13:33 T:6536 M:1356505088 NOTICE: UDP: Listening on port 9777
19:13:33 T:4008 M:1352273920 NOTICE: -->Python Interpreter Initialized<--
19:13:33 T:5132 M:1331544064 NOTICE: -->Python Interpreter Initialized<--
19:13:34 T:828 M:1314201600 NOTICE: -->Python Interpreter Initialized<--
19:13:34 T:7108 M:1313218560 NOTICE: -->Python Interpreter Initialized<--
19:13:35 T:4720 M:1339482112 NOTICE: -->Python Interpreter Initialized<--
19:13:35 T:7744 M:1339281408 NOTICE: -->Python Interpreter Initialized<--
19:13:35 T:8060 M:1339281408 NOTICE: -->Python Interpreter Initialized<--
19:13:38 T:7108 M:1337573376 NOTICE: ### TV-Show Next-Aired starting ...
19:13:38 T:7108 M:1337573376 NOTICE: ### author: Ppic, Frost
19:13:38 T:7108 M:1337573376 NOTICE: ### URL: http://code.google.com/p/passion-xbmc/
19:13:38 T:7108 M:1337573376 NOTICE: ### credits: Team Passion-XBMC, http://passion-xbmc.org/
19:13:38 T:7108 M:1337548800 NOTICE: ### date: 12-10-2010
19:13:38 T:7108 M:1337569280 NOTICE: ### version: 2.0.1
19:13:38 T:7108 M:1337569280 NOTICE: {'alarm': '3600', 'silent': 'True'}
19:13:38 T:7108 M:1337454592 NOTICE: ###db less than 24, fetch local data...
19:13:38 T:7108 M:1337073664 NOTICE: ### Load list: C:\Users\Psike\AppData\Roaming\XBMC\userdata\addon_data\script.tv.show.next.aired\next_aired.db
19:13:38 T:7108 M:1336504320 NOTICE: ###data available
19:13:38 T:8060 M:1336352768 NOTICE: ### TV-Show Next-Aired starting ...
19:13:38 T:8060 M:1336352768 NOTICE: ### author: Ppic, Frost
19:13:38 T:8060 M:1336352768 NOTICE: ### URL: http://code.google.com/p/passion-xbmc/
19:13:38 T:8060 M:1336352768 NOTICE: ### credits: Team Passion-XBMC, http://passion-xbmc.org/
19:13:38 T:8060 M:1336348672 NOTICE: ### date: 12-10-2010
19:13:38 T:8060 M:1336348672 NOTICE: ### version: 2.0.1
19:13:38 T:8060 M:1336274944 NOTICE: {'alarm': '3600', 'silent': 'True'}
script is lauched two time ...
have you modified the skin ?
Mcbrozu, where have you put the script start?
ppic Wrote:Code:
ctrl+f the word "runscript" in includes.xml. I have it wrapped in an include that is referenced in startup.xml and home.xml
startup, ok, why home ? it launch each time you go to home this way no ?
is this the same way as when we test ? i've never encoutered that behaviour
ppic Wrote:startup, ok, why home ?
well that's a problem because if you launch 2 alarm with same name, they are cancelling each other.
if user want to change skin, they'll have to relaunch xbmc to load the script the correct way
alarm works fine at startup.
So how would we be able to fix this? I didn't change anything on the skin btw.
Edit: nvm, just saw the release thread.
DEBUG: ------ Window Init (MusicKaraokeLyrics.xml) ------
15:11:30 T:3077937024 M:3138699264 INFO: Loading skin file: MusicKaraokeLyrics.xml
15:11:30 T:3077937024 M:3138699264 ERROR: unable to load:/home/xbmc/.xbmc/addons/skin.night/720p/MusicKaraokeLyrics.xml, Line 0
Failed to open file
15:11:30 T:3077937024 M:3138699264 DEBUG: Load MusicKaraokeLyrics.xml: 0.64ms
15:11:30 T:3077937024 M:3138699264 DEBUG: Alloc resources: 0.72ms (0.72 ms skin load)
15:11:30 T:3077937024 M:3138699264 DEBUG: Karaoke default background is set to none
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Missing some Karaoke support?
mcborzu Wrote:. If I'm going to guess people might be using the older version of the next aired script.
And where may we get an up to date download? I Just downloaded the one you linked is to.
This one
http://mirrors.xbmc.org/addons/dharma-pr...next.aired
Where might be the most up to date one?
Oddsodz Wrote:And where may we get an up to date download? I Just downloaded the one you linked is to.
This one
Seemed my guess was wrong, I was launching the script twice. The release thread has a fix -
HERE
Hello mcborzu,
did you manage to implement the record button for shoutcast ?
Sorry, if I get on your nerves
Raptylos Wrote:Hello mcborzu,
yes
