PatOso Wrote:You can add in the config menu option to remove "press left to see trailer", as there are people who do not use the default scraper and FilmAffinity example does not work. only causes discomfort when pressed by mistake.
Add I see some errors in the latest versions of night.
Greetings.
Not a bad idea for a global "Turn off one-click trailers" setting
I never had answered so quickly
, thank you for considering it would be a good option for many.
Greetings.
Do you have any plans to add Next Aired to the info screen?
It's nice in the couple views that support it but it might be a worthwhile addition here as well. ^_^
hikaricore Wrote:Do you have any plans to add Next Aired to the info screen?
Duh, never even crossed my mind. Definitely need it as some views you just can't fit it in...I mostly redid Movie info and quckly thru together TV/Episode. I still want to focus a little more on TV/Episode screen and will include it...
are you going to raise the episode title a little in the episode view? it's still a little tight to the text below it...
distracto Wrote:are you going to raise the episode title a little in the episode view? it's still a little tight to the text below it...
You mean this
view? I don't notice overlaps...
funny, mine looks like this
Just curious to why wall has been taken out of the view for trailers. with all the trailers from apple i like seeing all of them on a wall. Just curious.
thanks.
He edited "IncludesHomeRecentlyAdded" to view correct in Spanish
incorrect:
incorrect:
correct:
IncludesHomeRecentlyAdded.xml edited for Spanish:
http://www.megaupload.com/?d=BA70MX8L
Greetings.
Still loving Night, and now even more with the new Info screen. Been away for a while, and finally updated to dharma 4 and night 1.4.7. But I am having some trouble with fanart. Some of the fanart is just not showing. This is in my main (home) menu and in my movie library as well. The strange thing is that it does show fanart a minute later, but then after a while the fanart is gone again.
I use extrafanart for all my movies and I use multi-image for all my menus in the main menu.
I really don't understand this, can anyone help me? Thnx
R-Nol Wrote:Still loving Night, and now even more with the new Info screen. Been away for a while, and finally updated to dharma 4 and night 1.4.7. But I am having some trouble with fanart. Some of the fanart is just not showing. This is in my main (home) menu and in my movie library as well. The strange thing is that it does show fanart a minute later, but then after a while the fanart is gone again.
Thats odd, haven't heard anything like that for Night or any other skin for that matter...
Could delete your
userdata/Database/textures.db and see if that cures it...
venealis Wrote:Just curious to why wall has been taken out of the view for trailers. with all the trailers from apple i like seeing all of them on a wall. Just curious.
thanks.
Lazy solution, I have some specific labels for AMT but only for Poster view plus I didn't want a 100 views for that addon maybe 1-3 views available for AMT - Poster/Wall/Showcase...
Thnx mcborzu, deleted the textures.db and everything is fine now.
mcborzu Wrote:Lazy solution, I have some specific labels for AMT but only for Poster view plus I didn't want a 100 views for that addon maybe 1-3 views available for AMT - Poster/Wall/Showcase...
Sounds good. I'm a Showcase fan myself.
I have movie trailers saved locally and added the source as a Fave and added to the home menu - but not included in the Library of course. Showcase isn't one of the views available there. There's only 3 I believe? Must be a default setting for viewing a source directly (via Videos menu) since not in the Library?Can you add Showcase as one of the defaults?
