mcborzu Wrote:Yea only way to get Season Landscape is to use them as your main...
does that mean no specific season landscape images for tvshows ? to bad then i guess (still loving the skin
) would be a nice feature maybe
i checked it works in other skins (no idea how different the skins function as in code) just pointing it out
no harm intended
distracto Wrote:funny, mine looks like this
do you know why my episode text is lower than yours?
distracto Wrote:do you know why my episode text is lower than yours?
Sorry, I gotta start writing requests/bugs on the first page like I used to, as I'm forgetting stuff but yea no clue why that's happening but I'll bump the title up a few pixels and problem will be solved and no harm done...
How about just using github? Got nice and simple notebook-like bug tracker
ventech Wrote:How about just using github? Got nice and simple notebook-like bug tracker
Yea and now with two skins I'll probably have to go that route
Im having some issues with plugins. I've set plugin content to "episodes" but it still wont look the same.
Season/episode should be hidden when it isnt set
Title's not showing in this view
For plugins info screen looks like this:
..while in the tvshows directory it looks like this:
mcborzu Wrote:Gotta address those...What plugin was that btw...
Its not in the repo yet but there are others you cant test it on. tv3 for instance.
But i figured out why title didnt work. Its because
that view uses the TVShowTitle parameter while some of the other views use normal title. This also fixes the info screen so i guess you can never mind about 2 and 3. Hiding season/episode would still be nice tho.
We just added support for movie set in Ciné-Passion, and a lot of users from passion-XBMC (myself included) requested a way to recognize them while navigating, as does the watched overlay for already watched movies. As in this screen for example :
http://i620.photobucket.com/albums/tt289...hot057.png
Do you think you could create a movie set overlay ?
Maxoo Wrote:We just added support for movie set in Ciné-Passion, and a lot of users from passion-XBMC (myself included) requested a way to recognize them while navigating, as does the watched overlay for already watched movies. As in this screen for example :
consider done, as of now I have it in text, I add a watched overlay type flag...
Strange idea, have the skin look for banner.jpg for the non poster/lanscape view.
then when you have the logo script set to download banners as well.
I have a little problem in MusicLibrary.
On the screen, only 18 songs appears, the 19th is hidden...
Can you fix it ?
Xnorky Wrote:Hi,
Can you fix it ?
Fixed on git...
bumped spacing up a few pixels, fixed on git...
is there tvtunes script support in the skin or do i need to add it manually?
thanks
