2011-03-24, 01:46
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
2011-03-24, 03:24
PatOso Wrote:The photos of the cast may be smaller?
Very ugly with the current size
THX
Night return to work? you tired of Black Ops? mcborzu.
I concur with cast, yes pretty much done with Black Ops now just play if my buddy calls...
Got a big todo list:
Cast/info screen makeover
Now Playing Music makeover
Advanced Launcher update
TvGuide
Redo Recently added Home
PseudoTV - done!
Couple other things that escape me at the moment...
Right now cant decide if I want to do a big update or minor touchup for the Repo update...
2011-03-25, 00:35
mcborzu Wrote:I concur with cast, yes pretty much done with Black Ops now just play if my buddy calls...
TvGuide
PseudoTV - done!
Minor pretty please
2011-04-23, 01:57
I might be overlooking a toggle or something. But I think the start from beginning / resume prompt seems to be missing.
2011-04-23, 02:01
hams1000 Wrote:I might be overlooking a toggle or something. But I think the start from beginning / resume prompt seems to be missing.
No clue, never heard of that before.
2011-04-23, 02:11
2011-04-23, 02:56
2011-04-23, 04:15
No Clue on the problem my self
2011-04-24, 02:11
Sorry id-10t error on my end. It is prompting me to resume. I was trying it on unwatched videos.
2011-05-09, 05:38
I'm using the SVN Repo version (1303258124) and I've found an issue when I try to run the Logo script on shows with a comma in the title. i.e. "Clone High, USA" is the item I was troubleshooting on.
Here's what my log file wrote:
22:18:42 T:2435988336 M:1594142720 NOTICE: ['script.logo-downloader', 'mode=solo', 'logo=True', 'clearart=True', 'showthumb=True', 'showname=Clone High', 'USA']
22:18:42 T:2435988336 M:1594142720 NOTICE: arg 0: script.logo-downloader
22:18:42 T:2435988336 M:1594142720 NOTICE: arg 1: mode=solo
22:18:42 T:2435988336 M:1594142720 NOTICE: arg 2: logo=True
22:18:42 T:2435988336 M:1594142720 NOTICE: arg 3: clearart=True
22:18:42 T:2435988336 M:1594142720 NOTICE: arg 4: showthumb=True
22:18:42 T:2435988336 M:1594142720 NOTICE: arg 5: showname=Clone High
22:18:42 T:2435988336 M:1594142720 NOTICE: arg 6: USA
22:18:42 T:2435988336 M:1594142720 NOTICE: no arg7
22:18:42 T:2435988336 M:1594142720 NOTICE: ### Start Solo Mode
22:18:42 T:2435988336 M:1594142720 NOTICE: Traceback (most recent call last):
22:18:42 T:2435988336 M:1594142720 NOTICE: File "/home/xbmc/.xbmc/addons/script.logo-downloader/default.py", line 417, in get_tvid_path
22:18:42 T:2435988336 M:1594142720 NOTICE: self.tvdbid = match[0][0]
22:18:42 T:2435988336 M:1594142720 NOTICE: IndexError: list index out of range
22:18:42 T:2435988336 M:1594142720 NOTICE: sql dat: select tvshow.c12 , path.strpath from tvshow,tvshowlinkpath,path where tvshow.idShow=tvshowlinkpath.idshow and tvshowlinkpath.idpath=path.idpath and tvshow.c00="Clone High"
22:18:42 T:2435988336 M:1594142720 NOTICE: xml dat:
22:18:42 T:2435988336 M:1594142720 ERROR: Error Type: exceptions.TypeError
22:18:42 T:2435988336 M:1594142720 ERROR: Error Contents: unsubscriptable object
22:18:42 T:2435988336 M:1594142720 ERROR: Traceback (most recent call last):
File "/home/xbmc/.xbmc/addons/script.logo-downloader/default.py", line 643, in ?
downloader()
File "/home/xbmc/.xbmc/addons/script.logo-downloader/default.py", line 143, in __init__
self.solo_mode()
File "/home/xbmc/.xbmc/addons/script.logo-downloader/default.py", line 150, in solo_mode
self.id_verif()
File "/home/xbmc/.xbmc/addons/script.logo-downloader/default.py", line 426, in id_verif
if self.tvdbid[0:2] == "tt" or self.tvdbid == "" :
TypeError: unsubscriptable object
When I manually edited the title to remove the comma, the script ran just fine. Thanks for the great work on the skin.
downloader()
self.solo_mode()
self.id_verif()
2011-05-09, 08:10
traeblain Wrote:I'm using the SVN Repo version (1303258124) and I've found an issue when I try to run the Logo script on shows with a comma in the title. i.e. "Clone High, USA" is the item I was troubleshooting on.
downloader()
self.solo_mode()
self.id_verif()
Try Posing this in the Logo Scripts forum. You already narrowed the problem to it. Don't place problems with it in the SKIN forum.
Logo Downloader Script Forum: http://forum.xbmc.org/showthread.php?tid=74912
2011-05-29, 21:09
is there a way to shutdown the computer from within Night? the "shutdown" in the menu I found only exits xbmc.. confluence has a "shutdown the pc" menu item that turns off the computer
2011-05-29, 22:59
X:\Users\User Name\AppData\Roaming\XBMC\addons\skin.night\720p
Open "DialogButtonMenu.xml"
<control type="button" id="3113">
<description>Shutdown</description>
<height>30</height>
<width>170</width>
<textoffsety>4</textoffsety>
<font>LiberationSans_Regular_20</font>
<textcolor>MainBlack</textcolor>
<focusedcolor>white</focusedcolor>
<texturefocus border="5">confluence/button-focus.png</texturefocus>
<align>center</align>
<aligny>middle</aligny>
<label>$LOCALIZE[13005]</label>
<onclick>ShutDown()</onclick>
</control>
Replace
<height>30</height>
<width>170</width>
@ <onclick>Powerdown</onclick>
</control>
Enjoy
2011-06-03, 01:03
2011-06-03, 03:27
KiSUAN Wrote:Little "bug"
http://forum.xbmc.org/showpost.php?p=810388&postcount=2
Someone asked me to switch something so I was going to remove the "Files" button but now I forget what I was going to put in that spot.
Either way that files button will be gone when I move to the Nightlies soon...
