2010-05-15, 06:23
I see a strange behavior with the Music library on my Xbox. Some artist (not all) that have the "and" word in it are duplicated. As an example:
Albert King and Stevie Ray Vaughan
Albert King & Stevie Ray Vaughan
As you can see, both entries are there, but only the one with "and" in it is valid (the file and the MP3 tag are named with "and").
So I decided to test a bit further. If I change the filename and the MP3 tag to use the amp sign (&) instead of "and" I see only one entry. It is a good workaround and I don't mind renaming my files, but I'd like to see if someone have seen that problem before? Is it a bug that's worth submitting to the bug tracker?
As I said before, this behavior is NOT seen with all artists with "and" in the name, just some of them. Here are some more details about my environment:
- Xbox version 1.4
- Music is on a Samba share
- I use XBMC T3CH bins rev28472 (last rev is crashing a lot but I can update for testing if absolutely necessary)
I can also install XBMC on Linux and Windows if needed.
Thanks,
Jean-Philippe
- Xbox version 1.4
Thanks,
Jean-Philippe
