Full Version: [MAC] Changed location for skins? scripts?
I'm using build 30260 and SL 10.63
It seems the install location for skins have changed?
For the time being, at least.
Before it was ~Library/Application Support/XBMC/skin
now it's in the addons folder inside the app itself:
XBMC.app/Contents/Resources/XBMC/addons
where you find the default skins: skin.confluence and skin.pm3-hd
And I guess the folder name should reflect the contents?
Like in "skin.Transparency", which works for me.
How about scripts, I can't get navi-x to show.
I tried renaming it "script.Navi-X" and place it in that same folder but no go.
Anyone experiment more with this?
oh, okey according to this downgrading to Revision 28276 or below should be better. (Maybe that info should be pinned?)
But that was posted almost 3 months ago so if anyone have a trick for scripts in the meantime, like mine with the skins.....
