Full Version: Unable to play VDR Recordings in PVRTESTING2
I am not able to play any recordings from VDR backend. Recording via VDR works perfectly. MPEG2 files ( *.vdr -from vdr 1.6.0 and *.ts - vdr 1.7.x ) and H264 files ( *.ts ) works perfectly via Videos - Play. But If I want to play recordings via Live TV -> Recordings XBMC always freeze. After few minutes message box said "Unable to play video"
I tried to play this video with and without VDPAU but wit no success.
Live TV from VDR backend works perfectly via Streamdev and VNSI too.
Configuration :
OS Mandriva 64b / Mandriva 32b same result - XBMC freeze
NVDIA drivers v. 195.36.24
Streamdev - cvs, VNSI - last version
XBMC - pvrtesting2 , svn version
VDPAU enabled/disabled, AdvancedGLX, Basic GLx,SW same result
VDR backend on local machine and tested with VDR on the other machine.
compiled with > ./configure --enable-vdpau --disable-pulse --enable-dvdcss --enable-mid --prefix=/usr
Have anyone same problem ?
Excuse me my bad English. Thanks
Logs >
12:34:30 T:140046444464400 M:1159753728 ERROR: AddOnLog: pvrclient/VDRClient for streamdev: Couldn't connect to 127.0.0.1:2004: Úspěch
12:34:30 T:140046444464400 M:1159753728 DEBUG: AddOnLog: pvrclient/VDRClient for streamdev: closing connection (res was -1)
12:34:30 T:140046444464400 M:1159753728 ERROR: AddOnLog: pvrclient/VDRClient for streamdev: CVTPTransceiver::Connect - failed to connect to IP '127.0.0.1
12:34:30 T:140046444464400 M:1159753728 ERROR: PVR: No video or audio data available after 15 seconds, playback stopped
I found patches in pvr-testing2/xbmc/pvrclients/vdr-streamdev/patches/ .
Its necessary to aply at least 3 patches ( streamdev-cvs221109-* ) to streamdev plugin !
After that recording plays verwell !
