When i first installed xbmc, when booting it the full window was xbmc, i hit something during confusion and how i see the window bar at the top withe _ and the box and X at the top, how do i make it go away and go back to full screen xbmc.
Hit \ to toggle back and forth from fullsceen to windo.
SlaveUnit Wrote:Hit \ to toggle back and forth from fullsceen to windo.
They what? / do i have to hit ctrl or alt? it's not working.
anyone have a solution please?
Pressing backslash works here.
As a last resort search your C: drive for a file called guisettings.xml. It will be in your userdata folder, which will be "C:\Program Files\XBMC\userdata" in portable mode or in your profile in default mode. You may find more than one copy of this file.
Rename all copies of the file to oldguisettings.xml. Now start XBMC and this will set XBMC back to the default display settings.
JR
