2010-05-20, 07:50
hi,
i am using linux mint 9 (pulseaudio), and use an iec958 connected to an AVR.
i read 10 pages, for around 2 hrs, but couldn't quite find a solution to my problem.
this is my aplay -l:
already confuses me, shouldn't there be anything called "iec958"?
this is my configuration inside xbmc:
but as soon as i try to play anything with AC3 or DTS, i get:
then i have to open the filespecific settings, put "all speakers" on and off, and its working:
heres the log:
what is wrong here, or what am i doing wrong?
thanks in advance for any help
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: SB [HDA ATI SB], Gerät 0: VT1708S Analog [VT1708S Analog]
Sub-Geräte: 2/2
Sub-Gerät #0: subdevice #0
Sub-Gerät #1: subdevice #1
Karte 0: SB [HDA ATI SB], Gerät 1: VT1708S Digital [VT1708S Digital]
Sub-Geräte: 1/1
Karte 1: HDMI [HDA ATI HDMI], Gerät 3: ATI HDMI [ATI HDMI]
Sub-Geräte: 1/1
heres the log:
Quote:17:08:30 T:2949630832 M:1660596224 NOTICE: Creating audio device with codec id: 86020, channels: 2, sample rate: 48000, pass-through
17:08:30 T:2949630832 M:1660596224 ERROR: Initialize - device iec958:AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2 busy retrying...
17:08:30 T:2949630832 M:1653866496 ERROR: Initialize - failed to open custom device iec958:AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2, retry with default iec958
17:08:30 T:2949630832 M:1653866496 ERROR: Initialize - pcm_open_lconf, alsa error: -16 - Device or resource busy
17:08:30 T:2949630832 M:1653866496 ERROR: Creating a Null Audio Renderer, Check your audio settings as this should not happen
