2010-05-21, 17:39
Hey,
First I need to mention that I have been spoiled by M$ over the years and never really used Linux. A complete Linux noob.
I have just given XBMC Live a try and must say it is really awesome. Don't think I could go back to W7 MCE.
I have really shitty networking equipment but in the process of buying new stuff.
Anyway, I have installed XBMC Live to hard drive. I was given a D-Link DWA-520 wireless card and popped it in the machine. It 'works', gets weather and movie/tv show scrapes just fine.
The problem is when I try to copy to the shares over wifi from my Windows 7 laptop. I get 600kb/s but when I copy over a wired connection I get 3mb/s. I have a 802.11g router.
I checked and the system says it is currently using the Ath5 driver.
interfaces file:
samba conf:
Have even added:
wpa_supplicant conf:
EDIT: Using WPA2-PSK on router.
Any help would be greatly appreciated. Thanks
interfaces file:
# Wireless interface
auto wlan0
iface wlan0 inet dhcp
wireless-essid yournetworkname
pre-up wpa_supplicant -B -Dwext -iwlan0 -c/etc/wpa_supplicant.conf
post-down killall -q wpa_supplicant
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet dhcp
samba conf:
[drive1]
comment = XBMC Drive 1
path = /media/drive1
force user = xbmc
inherit permissions = yes
read only = no
guest ok = yes
[drive2]
comment = XBMC Drive 2
path = /media/drive2
force user = xbmc
read only = no
guest ok = yes
Have even added:
socket options = TCP_NODELAY IPOS_LOWDELAY SO_RCVBUF=8192 SO_SNDBUF=8192
ctrl_interface=/var/run/wpa_supplicant
network={
ssid="yournetworkname"
#psk="password"
psk=<removed>
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
group=CCMP
