Full Version: ImageLib.dll issue
A hoy,
So i keep running into this issue, and ive tried various different things to fix it. I am still unable to view my album art, although for some it shows up as like a secondary thumbnail to the basic folder icon.
WARNING: Unable to resolve: ImageLib.dll ReleaseImage
ERROR: Unable to resolve exports from dll Q:\system\ImageLib.dll
Ive tried redownloading the current t3ch build (which i am currently running) and replacing ImageLib.dll with the newly downloaded one thinking it might be corrupt, i read that people were deleting the mymusic7.db and having it work, and ive tried downloading the new nightly builds and replacing my ImageLib.dll with that. All to no avail. What are my other options here, and is there a magical ImageLib.dll somewhere out there that has been solving people problems, if so where do i get it?
Also, not sure if this would solve the other problem im having, but when i go to download movie info thumbs, the 'remote download' doesnt give me any images. Is this related?
-Andrew
Just went in and found i also had a mymusic6.db, deleted that one as well, still nothing.
Any ideas on this guys?
Sure thing, here it is:
http://pastebin.com/gTtVgVQ0
-Andrew
Whats it looking like?
I see you're using a skin called MARK-III - try using standard PMIII skin and see if you have the same problem.
Also, consider uploading the latest available T3CH in a separate folder (fresh install, do not copy your UserData and re-configure from scratch, and rescan your library), see if that looks better.
I tried it with the PMIII skin, same issue, i just changed back because this is the one i use. If you would like me to change to PMIII and submit a debug log i can, but the result is the same.
Ill give the seperate folder deal a try and see if i run into the same issue. Ill post back with the results. Since i have 25,000 songs my scan goes extremely slow, so ill probably post back tomorrow, as my last library scan lasted just over 6 hours.
Maybe scan first the ones you had a problem with...
10:43:11 M: 44896256   ERROR: CThread::staticThread : Access violation at 0x0026b311: Reading location 0x011b7000
Well, at least this doesn't look right. It's probably related though the cause is a mystery (must be triggered by your non-standard skin I guess)....
Didnt have a chance to get to it last night, but working on it now. Just to help out, heres the debug with PMIII (exact same issue)
http://pastebin.com/5uVRd6gK
Dan Dare Wrote:Also, consider uploading the latest available T3CH in a separate folder (fresh install, do not copy your UserData and re-configure from scratch, and rescan your library), see if that looks better.
Gave this a whirl, totally worked just starting from scratch. Transferred my scripts and plugins back, ill just reset my passwords and such. Havent resubmitted to the library yet, but just the regular folder view onto my comp is showing all the album art. Thank you for you help guys!
well done. You should consider using T3CH Upgrader script (http://www.xbmczone.com/plugin_details.asp?id=126), downloads both T3CH and SSHCS builds and install them in a separate folder so you can try them first. Also has the ability of transfering your userdata or not (fresh install).
