Full Version: Auto Fine info over network
On my local system files automatically display the resolution and even generate a pic if one was not already available. However when I access the same files over my network it does not support this feature. What do I need to do so that my networked files behave as they would locally. :confused2:
Perhaps I should post an example: on my local system I view a file that has no preview pic generated by the scrapper and one is automatically generated from the file. However if I look at this same pic on my remote setup this does not occur.
You're going to have to post a debug log before anyone can help you.
Oh, I just figured it was a setting option that I missed not an actual error but I will try to look up the debug and post it.
