With Windows media center I can use my satellite Set top box but I am not a fan of the player. I would really like to use XBMC with my satellite receiver? Would this be possible??
If you can install linux on it then yes!
linux on what...The satellite receiver
It's really a complicated answer withs if's and but's so just assume the answer is no. You'll know when there's a fully functioning version of Xbmc that will run on small STB's, and which one's it'll work on.
Ok, I'm sorry, I'm not asking the correct way. I have a xbmc computer and Dish Network. What I would like to do is run my Dish Network though my XBMC computer. So all my channels show up in XBMC. I know I have to hook RCA's or S-Video thorugh the computer from the dish network STB.
But how do I populate the channels in XBMC?
Thank you
Ah. You want PVR integration. This allows Xbmc to control a PVR backend system such as MythTV. If MythTV can control your Dish Networks receiver (presumably via an IR blaster) then yes it could be possible. It's a very new feature which I've not had the chance to experiment with myself so I can't comment any more.
http://forum.xbmc.org/showthread.php?tid...hlight=PVR
kraqh3d Wrote:Ah. You want PVR integration. This allows Xbmc to control a PVR backend system such as MythTV. If MythTV can control your Dish Networks receiver (presumably via an IR blaster) then yes it could be possible. It's a very new feature which I've not had the chance to experiment with myself so I can't comment any more.
I'm using MediaPortal as a backend and can view Analog cable in XBMC without channels in the guide. I would think hooking up a STB would be simple.
I know there are many threads out there on this. But I cannot pinpoint one that really helps me. Could some one please point me in the right direcetio?
Thank you
I will look into this too, very interesting
