Full Version: Quick question about XBMC live - is this possible?
Hi
I have a Revo 3610 currently running xbmc from win7 and it works ok.
I have a 250gig internal HDD which is partitioned to 30gig and 220gig. One for the OS and the other for files.
Im wanting to run XBMC live though instead from a USB stick i have, while leaving my partitions as they are. Ill just take the stick out when i want to use windows.
My question is this - I know i can run SABNZBD from xbmc live, but will it be able to download/extract to my second partition which will be NTFS from XBMC live?
johhhnnn Wrote:Hi
Yes, as long as your ntfs partitions are mounted. Extraction directory can be changed from the sabnzbd web config and ntfs drives can be mounted automatically on boot.
tdw197 Wrote:Yes, as long as your ntfs partitions are mounted. Extraction directory can be changed from the sabnzbd web config and ntfs drives can be mounted automatically on boot with a properly configured fstab.conf
Fixed
poofyhairguy Wrote:Fixed
Fixed fixed, no .conf.
