*Worked it out for myself, Just deleted the partition like it says on the boot-loader site.
I planed on doing the linux install to day but when I try and resize the media partition I get this error
Warning: The journal is not empty. Parted must replay the transactions before opening the file system. This will modify the file system.
This is what the disk looks like
Model: ATA WDC WD1600BEVE-4 (scsi)
Disk /dev/sda: 312581808s
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number Start End Size File system Name Flags
1 40s 69671s 69632s fat32 EFI boot
2 69672s 888823s 819152s hfs+ Recovery atvrecv
3 888824s 2732015s 1843192s hfs+ OSBoot
4 2732016s 312319663s 309587648s hfs+ Media
Any help would be appreciated.
DV3B Wrote:*Worked it out for myself, Just deleted the partition like it says on the boot-loader site.
before playing with parted;
fsck.hfsplus /dev/sda4
davilla Wrote:before playing with parted;
Thanks I'll remember that for next time
i am also stuck at this same error message, "Warning: The journal is not empty. Parted must replay the transactions before opening the file system. This will modify the file system."
I am following the instructions here:
http://wiki.xbmc.org/index.php?title=HOW...he_AppleTV
appletv 40gb, factory restored, upgraded to 3.02, atvusbcreator to install launcher and xbmc nightly build, and crystal tv driver r26.
when I run: "fsck.hfsplus /dev/sda4" it says "this volume is journaled. no checking performed. use the -f option to force checking." i do that, and it says the volume appears to be okay.
re-run parted, and still get same error.
help?
trevorcobb Wrote:i am also stuck at this same error message, "Warning: The journal is not empty. Parted must replay the transactions before opening the file system. This will modify the file system."
help?
unmount it, then do the fsck.hfsplus. if this does not work, then turn off the journaling for it under atv(osx).
Resize your partition to a larger size, then incrementally decrease. You most likely have files in the space it is trying to shrink
not able to unmount the partition in Linux booted off of USB memory stick, no matter what I tried. also could not disable journaling when SSH'd into the ATVOS.
kcarney's suggestion to incrementally downsize the parition using parted worked. I first did it to 70000000s then 65000000s etc... all the way down to 54525951s.
ubuntu is now downloading components for install.
thanks guys!
I have the same problem and i get the same errors with this line.
Also tried to make it bigger but the same problem persist.
Any ideas how to go further?
my disks looks like this now:
number start end Size File System name Flags
1 40s 69671s 69632s FAT32 EFI boot
after deleting the partition 4 and re-adding the media partition at the right size it all worked.
it also shows in the
print its hfs formatted.
now i added the sda5 and sda6 with
parted -s /dev/sda mkpart primary ext3 54525952s 77091549s
parted -s /dev/sda mkpart primary linux-swap 77091550s 78140126s
and doing the
partprobe /dev/sda
but if i look now at the disks it shows a nice 6 partitions but after sda5 and sda6 the is no file system table to show.
so with my next command:
mkfs.ext3 -b 4096 -L Linux /dev/sda5
it comes back with:
could not stat /dev/sda5 --- no such file or directory.
What can i do about this one?
davilla Wrote:unmount it, then do the fsck.hfsplus. if this does not work, then turn off the journaling for it under atv(osx).
To turn off journal, in atvos:
diskutil disableJournal /dev/disk04s
where "disk04s" is the name of the device returned by mount command.
Turn it back on again: "diskutil enableJournal /dev/disk04s"
