Full Version: library popup when entering database
hi everyone,
can anyone help me out with this:
when I enter a directory like 'movies' or 'series' the first thing I see is a grey popup with a library mode in it. I allways need to uncheck it first before I can get to my video files. Quite annoying...
Anyone knows how to avoid/turn it off?
Thanks in advance!
You're not entering a directory. You're choosing the shortcut that take you to the "Movies" or "TV Shows" sections of the library, but you've not imported anything into the library. (Which seems odd as Xbmc should know that there are no Movies or TV Shows and the skin should hide those menu choices.)
Choose "Files" from Video. Once you do that, it sets the last video window as files, and you should be able to just select Video without having to go to the submenu. And if you're using Confluence, I believe there are skin options to completely hide those options.
