dominater01 Wrote:hey solver im having an error with getting a new session id i've tried 3.0 and 2.9 and still have this problem even got a fresh new build and this still shows up it was working erlier so how would i fix this i think i messed it up somehow
debug log > http://pastebin.com/HwuQxZNG
API changes again. I've updated svn so it should work now.
Grabbed me the latest SVN of Grooveshark (but using Beta2 r33776), seems not to play songs anymore.
xbmc debug log:
http://pastebin.com/gkc9GEd2
Hi I changed my grooveshark password. I changed it in the script settings too match, but it wont let me log in. It tells me to 'check my login details'.
I am pretty sure I am using the right password, as I had to change the password on my android phone also.
Any Ideas ? Thanks.
I just installed the add-on, and get this error: "Unable to get a new session ID. Wait a few minutes a...". Well... I've waited quite a few minutes now, and it still doesn't work. A well known error?
I've asked for a pull from my repo. It should fix the problems people have been having with logging in and getting a new session id. If any of the problems persist please supply a debug log when you report the problem.
Another thing; are people interested in a user manual for the script?
Cheers,
Solver
PantsOnFire Wrote:Grabbed me the latest SVN of Grooveshark (but using Beta2 r33776), seems not to play songs anymore.
xbmc debug log:
There's no indication in the log that you are trying to play a song. It seems as if you just opened and closed the script. Any chance that you uploaded the wrong log?
Skisax22 Wrote:hi, sorry for the delay the last week has been pretty nuts. here should be the debug file
http://pastebin.com/yjnsaxdh
Is it me or is the log you uploaded empty?
solver Wrote:Hi,
Cheers,
Solver
I don't know what you mean by "pull from my repo", but I still get that error... Installed the program a couple of hours ago.
How do I supply a debug log?
stigroar Wrote:I don't know what you mean by "pull from my repo", but I still get that error... Installed the program a couple of hours ago.
Sorry, it means that I've asked the maintainers of the XBMC repository to add the newest code from my repository. So in an hour or two (but be patient - it might take longer) you should get notified that a new version (0.3.1) is available. Update and you should be good to go.
solver Wrote:Is it me or is the log you uploaded empty?
crap, let me try that again
Sounds great. Thanks!
stigroar Wrote:I just installed the add-on, and get this error: "Unable to get a new session ID. Wait a few minutes a...". Well... I've waited quite a few minutes now, and it still doesn't work. A well known error?
Wonder if somebody knows a solution for this new session ID.
Installed today V 0.2.9 on my Beta 2 Dharma and having this message en then script stops.
I am using dharma release and cirrus skin. Grooveshark loads + play fine but if i leave the screen, ie to home page or music visualisation, I can't seem to get back to grooveshark (although the music continues to play in the background). Clicking on grooveshark again makes no difference. The only way is to restart XBMC.
Ideas ?
