2011-02-22, 17:23
Whenever I enqueue songs they never seems to enqueue, it just plays down the current Popular list.
Should I just set up a playlist and add to that instead?
solver Wrote:I'll have a look at it
solver Wrote:Good suggestions. I'll see if I can't remember to implement it in the next version. Do you mind putting them in the issue tracker so I don't forget?
maruchan Wrote:Hey solver, thank you for all of your hard work on this awesome script I'm having an issue where I can't load my playlists. It just spins the little loading animation for a bit and then stops. The debug log can be found below:
https://pastee.org/9tn5e
fiddystorms Wrote:Ummm... Oh yeah
Can someone help me figure out what I need to do to add playercorefactory.xml so that it is only used by grooveshark? In other words I don't want any of my other programs which are running smooth with the current installed players to be affected by my adding an external player. I just want to solve the cache issue as explained on the first page. Grooveshark currently takes a long time between songs.
I looked to see if I have playercorefactory.xml and I don't. I want someone to point me to the code I can use that will work with grooveshark only and I will add the code from page 1 that solves my cache issue. Thanks for whatever help you can give me.?
denhams Wrote:The very first post of this thread tells you how to do this (http://forum.xbmc.org/showpost.php?p=542102&postcount=1). Look under the "FAQ" heading. Also, I think you can select the player in the script settings (use DVDPlayer to avoid the delay).
Stephen.
fiddystorms Wrote:If I create a playercorefactory.xml file and add that code and choose it as the default player for GS through settings, is that enough to play the file
javiertoti Wrote:I can't run it in a XBOX. What version need I?It doesn't run on XBOX. It may in the future but at the moment I'm not sure. Have a look at Denhams plugin which I believe runs on the XBOX.
rflores2323 Wrote:Got some questions. On the home menu Or menu on the side I can't see what is highlighted. It shows up a grey but very very light. Running 0.4.0. how can I change this so that it actually highlights.
My thumnails for albums are not coming up on my playlists. Im on atv2.
solver Wrote:I've had a look at the logs people have uploaded for this issue. It seems that requests to "https://" addresses are blocked. Please have a look at your firewall settings - it might be what is causing the issue. Also, what happens if you open https://cowbell.grooveshark.com/more.php in a browser - what is the response?¨
solver Wrote:For some reason, the build on atv2 doesn't load all textures. I don't own an atv2 so I can't really debug it. You can try to fix it yourself by editing grooveshark.xml. Search for 'id="500"', scroll down till you see '<focusedlayout height="35" width="210">'. Just below that you'll see '<visible>ControlGroup(400).HasFocus</visible>'. Try changing that to <visible>true</visible>
I have no idea why it's not loading the thumbnails though
