Full Version: BuildDependencies error
Hi
when running DownloadBuildDeps.bat i just `Code\XBMC' is not a reconized as an internal or external command & get a screen full of the system cannot find the path specified.
Even copied the source code dir to another drive so it was'nt in a load of sub directories eg "X:\xbmc" & ran it again & still get the same errors.
OS is vista if that helps
What have i missed??
thanks
I also had troubles with it last night. My solution was to rename the SVN dir from "XBMC SVN" to just "SVN" it didn't like the space. But I see that you have already tried that?
Thanks mindweaver renaming fixed it.
I followed the instructions here to build from source
http://wiki.xbmc.org/index.php?title=HOW...ource_code
but there is no DownloadBuildDeps.bat as indicated in the instructions
nm i found it
