2010-05-25, 10:54
2010-05-25, 11:01
Got that one myself, and yes, it works out of the box with live
Can recommend that one, fast and very good quality considering the price.
2010-05-25, 11:43
Thanks than I am gone buy some today.
One thing does the standby and resume work with this remote with xbmc live?
2010-05-25, 12:56
It works just fine as well with a little tinkering :
http://wiki.xbmc.org/?title=Enable_Wake-On-Device
2010-05-25, 16:37
In lirc, did you set it to Microsoft Remote or MCEUSB? I need to buy a new remote for a second installation but i have had bad experiences with ones that emulate keyboard button presses, i want a TRUE MCEUSB device. Is this a true MCEUSB remote? what is it listed as in lsusb when it is connected?
Also is this the same remote?: http://cgi.ebay.co.uk/HP-MCE-REMOTE-CONT...19bc794d3a
Cheers!
Cheers!
2010-05-25, 17:07
I have one of these eBay cheapie "HP" mce remotes too. Mine reports as and is a 1st generation mceusb lirc device, which sends remote pulses and not key presses.
You can never really tell what you're going to get when you order a knockoff product shipped from Hong Kong on eBay. Obviously these are not officially licensed products so you get what you get. If it is the HP-style device pictured then you have a pretty high chance of it being an actual mceusb remote and not a HID device.
045e:006d Microsoft Corp. eHome Remote Control Keyboard keys
2010-05-25, 17:21
Thanks CapnBry!
The sad thing is i don't even want/need the remote, i just need a receiver, mce is just the simplest i have found to emulate on my remote. I will give it a go as i don't fancy spending £50 on a receiver :-).
2010-05-25, 18:27
there's also a load of receiver-only offers on ebay, directly from your most loved HK sources
and yes, also the harmony remotes work 100% with these HP receivers in Windows MCE PC mode (which by default speaks philips RC6 protocol, most cheapie HK receivers can't do nothing with these signals)
2010-05-26, 07:23
XBMC really does need an official remote. :/
I wish I had a solution for that.
I'm surprised that someone like Zotac hasn't put something together. :\
