Full Version: Lucid SVN PPA and svn28256?
Hello all:
I know that the SVN PPAs have been frozen until the new addons are properly integrated. However, it appears that the last PPA build -- revision 28256 -- failed to build for Lucid, but succeeded for all the others. I'm using the last successful build on my Lucid-based HTPC, and it's working fine, but I'd really like to have 28256 on there, as it has support for a central MySQL library.
Is there any way that somebody on the dev team could fix the existing PPA build, or do I just have to check out the revision and build it manually? Thanks!
