On my previous install I had the revision3 plugin among others. I want to try and get them back I'm not sure how to put in plugins for these new versions. How do I put it on this version?
You probably arent going to get support on this because it has been said time and time again...do not get the SVNs right now because they are in a major overhaul.
no worries. I'll just keep combing the net maybe it will eventually get resolved
The 10.5 should be out pretty soon. So maybe just wait for that. Then everything will be explained and supported again.
Keep checking the roadmap.
http://trac.xbmc.org/roadmap
So far it's still slated for 5.30
