2010-05-26, 22:41
I'm creating this thread, as although I have similar symptoms to the consume packet error, I have different errors.
I have an ASROCK ION 330, normal, non BD, non HT.
It has the standard 320gb hdd and 2gb ram. With windows 7 and xbmc I get smooth playback of all videos.
Under linux I am getting juddery video. I've spent ages (a week) trying various xorg configs, and have tried minimal install of karmic and lucid. I've now got a full desktop install of lucid.
I've also tried the xbmcfreak live cd v14, and it shows the same behaviour. I've tried overclocking in the bios, and i've tried different ram. I've also tried disconnecting the hdd while running live cd, and disconnecting the dvd drive while running from hdd. I've also tried running from usb stick. All with the same error.
I've tried nvidia drivers 185,195 and 256beta
I've tried ALSA 1.0.20 upto 1.0.23
I've tried XBMC versions 9.11 stable and the SVN from the ppa.
So, here are the logs.
720p, playback is fine (pretty much) - http://pastebin.com/qSqiygLq
1080p, full avatar rip, bad jerking once per second - http://pastebin.com/RaFKdZ48
1080p, cars full bluray rip, not as bad as avatar, but similar - http://pastebin.com/LxFgBNLN
Sample file which shows the error for me: http://www.multiupload.com/6P70YAE9TZ
the SPS errors in the avatar log have 24 errors per second. this must be related to the 24fps video framerate, or display refresh, and I see one frame jump per second.
Interestingly I have a Q6600, with 4gb ram, and a nvidia gt240. I see the same issue with the xbmcfreaklivecdv14.
Is it hardware? I'm not sure, because it works in windows.
Is it software? I'm not sure because no-one else is reporting the same issue.
I am pulling my hair out, any help would be appreciated.
