davilla Wrote:I'd like to see the MediaInfo output for that file.
thanx alot for reading!!
let me add... I'm totally sure it's something up to the file, I commonly play 720 and 1080 streams without problems. Just curious why quicktime can handle it correctly and xbmc not.
here is the file info:
General
Complete name : /Volumes/xxxx/Aladdin.mkv
Format : Matroska
File size : 3.13 GiB
Duration : 1h 26mn
Overall bit rate : 5 167 Kbps
Movie name : Aladdin (1992)
Encoded date : UTC 2010-05-17 05:18:14
Writing application : mkvmerge v2.3.0 ('Freak U') built on Sep 9 2008 17:43:22
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Cover : Yes / Yes / Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Format settings, GOP : M=1, N=5
Muxing mode : Container
[email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 26mn
Bit rate : 4 156 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Original frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.180
Stream size : 2.56 GiB (82%)
Writing library : x264 core 65 r1016 dbc5ef0
Encoding settings : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.9:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4156 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=21 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70
Language : English
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 26mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 238 MiB (7%)
Title : Italiano
Language : Italian
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1h 26mn
Bit rate : 448 Kbps
Stream size : 278 MiB (9%)
Title : Disney Home Theatre Mix Ita
Language : Italian
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Forced
Language : Italian
