Full Version: Extend area for messages
I use EventGhost to send messages to my XBMC clients around the house for home automation messages, incoming calls and such (Notification via the http api).
It would be great if the background used for those "dialog windows" could extend to match the maximum length (before text start scrolling).
Most part of those messages appears outside the white background as it is today.
Possible?
It should be possible, I actually want to thank you for asking this as it is one of those things I wanted to fix with my mod. I will try to document the changes so you can apply it to a different mod or the original Alaska.
If you're interested there are actually min and max attributes for the width and height tags for controls, which is most likely all that needs to be changed for this to work.
Great! Please let me know how to do it after you're done.
