Full Version: Getting duplicates everytime I Scan for videos
Hey
Hoping someone can help......
To start things off, I have 2 MOVIES source drives connected to a network device.....XBMC reads them no problem, however it seems as though when I add movies to my 1 drive it scans TWICE and duplicates each one. I have looked in 'sources.xml' and this device only appears once.
Where else could I look or what else would be causing this issue?
It's driving me INSANE! :p
Look in your database. You'll have 2 paths there that are actually the same - probably one with user/pass information and one without. Easiest thing to do is probably delete the db and start over.
jmarshall Wrote:Look in your database. You'll have 2 paths there that are actually the same - probably one with user/pass information and one without. Easiest thing to do is probably delete the db and start over.
Thanks a lot, I will try deleting the Database for my videos, power OFF/ON and let it rescan on reboot and see how it goes. I will report back! Nod
That seems to have done the trick, thanks a lot. I will know for next time. Smile
