Full Version: [WINDOWS] Are the current builds stable enough?
I was wondering, before ruining my database, if the new 3x SVN versions are usable enough to use it on a daily basis? I'd like to test all the new features, and just install daily builds. But I don't want to miss important features like the scraper and stuff like that..
It seems more people are using the daily builds everyday, so my question is if it is reasonable stable atm.
Just backup your db or install to a different directory and copy your userdata across then you can test yourself
I have my stable build then test builds installed to C:\Program Files\XBMC2\ in portable mode no need to ruin your database
