Full Version: animation delay only once?
I'm trying to get 2 pics slide around the screen one after another, just to come to screen from one side and leave on the other and then loop it.
so I simply added slide effect to both only the second with a delay.
the problem is that delay kick in every loop. so if it start with delay=100 from the first pic, by the second round ot the loop it will be 200.
Is it possible making this delay only once at start?
Or is there anything else i can do to get this effect?
"Pulse" does only use delay on start, maybe you can do something with that attribute
Or would making the second one simply start further offscreen work?
Hitcher Wrote:Or would making the second one simply start further offscreen work?
already tried that. basically that worked but not as i expected. when the 2 pics follow each other at the same speed you have to wait till both of them off screen till the loop kick in. It's not what i want, I want always something is on screen.
