Full Version: [LINUX] Menus all fade to white
Quote:1. "Latest" is NOT a revision, of ANYTHING! (See below)
1:9.11-karmic1
Quote:2. Linux Distribution and Version (eg. Ubuntu 8.04, Gentoo 2007.0-r1, etc)
Ubuntu 9.10 with with Via CX700 S3 Unichrome Pro (rev 3) running packaged openchrome driver version 1:0.2.903+svn758-0ubuntu1
Quote:3. Architecture (eg. i686, x86_64, etc. See below.)
i686
Quote:4. Install Method (PPA, RPM, build.sh, manual, other)
PPA
Quote:5. SVN Revision (See below.)
Not sure svn repo installer says 1.8.2a-r1335 in log but cannot view menus to follow instructions on finding version in program
Quote:6. Detailed Instructions to Reproduce the Problem (The more specific the better.)
Run XBMC and splash screen with XBMC logo shows white on a black background as I assume it should then the screen fades to white there is the word XBMC scrolling across the bottom in light blue writing
Quote:7. FULL Debug Log (Please use your favorite paste site! See below.) << NOT OPTIONAL!
http://pastebin.com/nysRgS1k
Quote:GUI Problems (Navigation, Finding options, Setup, Labels, etc):
Whatever comes as default in 9.10 repo version I have not changed anything
Thanks in advance,
paul
Bump
did you find a solution for this issue? I got the same problem here on a pico-itx based Artigo A1000 pc.
NOTICE: GL_VERSION = 1.2 Mesa 7.6
XBMC needs at least opengl 1.3 if I remember correctly.
Oh crap. Well, thanks. Will I be able to use an older version of XBMC Live?
No.
Crap again - but thanks Smile i guess i'll stick to Win XP MCE then. Maybe i can try to install XBMC for Windows...ye, i'll give it a go. Cheers mate Smile
Edit: just installed the latest XBMC under WinXP..works like a charm Smile
