Full Version: Some tv shows have no episodes
I'm using XBMC 9.11 on Windows XP 32bit
For a couple of shows, no episodes show up in the list even though I have them all in the correct folder and they have shown up in the past.
The fanart and thumbnails are there, but opening up the show from XBMC just gives me an empty list with the option to go up one folder.
The folder has an nfo file, along with the thumbnail and fanart as I said above - I've tried re-scraping my entire TV show folder, I've exported and imported everything many times over, I've cleaned the library after everything I do, restarted both XBMC and even the PC just to be on the safe side, and it seems these shows just dont want to be seen anymore... Confused
If it makes any difference, the shows are I'm Alan Partridge and Max & Paddy's Road to Nowhere - it may be worth noting that I had issues with scraping Max & Paddy from XBMC, I had to manually get the artwork.
Create an NFO for an episode and see if it remedies the situation.
Worked! Thanks very much Smile
