2010-05-30, 01:17
Is there any way to place the XBMC system into a suspend S3 state from the HTTP-API. The HTTP-api allows you to shutdown the system but I did not see a method to suspend it to RAM. (sleep state s3). I would like to do this in my theater when I shut the theater down, and then use WOL to wake it up (if that works??)
TIA, Any advice/help appreciated.
