Can someone please tell me which button exits XBMC to windows? I'm using sleep mode (standby) as standard shutdown mode, but sometimes I want to go straightly to windows for surfing or other stuff. In stead of opening the shutdown menu and choosing the exit option, I would like to assign a button to my remote in order to exit to windows automatically.
Or maybe I can use a code in the keymap file?
You may switch between running tasks (avoiding exiting) if you have a remote device like the logitech di novo mini
ALT + TAB
WINDOWS KEY + TAB (since Vista, using Aero)
Hope this helps... if you really need a key binding to exit XBMC I'd have a look @
http://wiki.xbmc.org/index.php?title=Default_Controls
good luck
Thank you, that's also a solution and a good idea. I will use ALT+TAB on my remote.
jiver Wrote:Thank you, that's also a solution and a good idea. I will use ALT+TAB on my remote.
You're welcome my pleasure
Now for the sake of it, if anybody have a clue how to manually bind a key with a direct XBMC exit function that could be grate too
I guess we're getting lazy
