2010-06-03, 21:12
I am down the point where I have only two basic issues on my XBMC system.
The system is XBMClive 9.11 running on an Asrock ION-330 Pro. It is controlled soley by TCPIP using the HTTP-API interace. Music and Videos are on an unRaid server sitting on the same subnet at 100 mbps. The output of XBMC is fed into an Anthem AVM-50v over HDMI at 1920x1060p60
My first issue has to do with music. I have a large collection of CD's ripped to FLAC format. If the CD was originally a stereo (two track) then XBMC plays it baxck fine. If however the CD was originaly a multichannel DTS CD (generally 5.1 channels) only white noise is procuced. I have seen this problem on my other system which is the Squeezebox Transporter by logitech, if I allow the Squeezebox to adjust the volume. If the Transporter volume and its server volume is set at 100% then the sound is perfect. I suspect it may be a similar issue. Does any one know of a solution to this problem?
The second issue is the inability to play the newer HD codecs that are on BR disks. I rip my BR disks with AnyDVD-HD and Clown BD. ending up with a standard BR container but missing the trailers and dire warnings. I also own a Dune player, and it has no trouble playing the newer codecs (True HD and DD MA)
Does anyone know of a solution to this issue.
